EFI Live?
Old Aug 17, 2006 | 03:10 PM
zspot98's Avatar
Default EFI Live?
Tried to hook up my car to a buddies EFI Live yesterday and it would not connect to the car. We then we took it over to his car and it had no problems connecting. Both cars are 98's, any ideas? Or does my car just suck. Thanks, Mike
Old Aug 17, 2006 | 03:21 PM
ringram's Avatar
Any errors?
In theory you can tune yours for free as efilive can do unlimited 98's
Post up on eflive as Im sure you will get more help there. Send the log file in etc.
Old Aug 17, 2006 | 03:22 PM
Steve Bryant's Avatar
LS1 Tech Veteran
I have not used EFILive on a '98. Why don't you go over to their forum http://forum.efilive.com/ and ask this question.
Steve
Old Aug 17, 2006 | 03:33 PM
Black02SS's Avatar
Does your cig lighter work?
Old Aug 17, 2006 | 04:34 PM
nonnieselman's Avatar
Yes i found out that the hard way.... If your CIG Lighter dont work... no power to the OBD port..
It will run you crazy tryin to figure it out.
Check for any Blown Fuses in your fuse box..
Have a good day!
Jonathan
Old Aug 17, 2006 | 04:35 PM
zspot98's Avatar
No it doesn't. Seems like the response I was looking for on this. I was assuming it was electrical, but wonder if anyone had heard of this before. What should I look into to fix this problem.
Old Aug 17, 2006 | 06:53 PM
Black02SS's Avatar
Have a good day!
Jonathan
Do as he says. Look for any blown fuses as that is likely the problem.
Old Aug 17, 2006 | 07:25 PM
zspot98's Avatar
Well after checking the fuses I found the culprit. Thanks all for the insight. Wished I would have known that fuse powered the OBD also. Thanks again, Mike.
