2 Bar MAP on a 1998 PCM
Old Aug 21, 2006 | 03:27 PM
APD*98SS's Avatar
Default 2 Bar MAP on a 1998 PCM
In the Gauge Display, I changed the properties of my MAP gauge to show the 2 Bar MAP, however, when I scan the 2 Bar is not functioning. The needle disappears. What gives?
Old Aug 22, 2006 | 12:17 AM
bmfcamaro's Avatar
i take it you have hptuners. you should post on their site as it will be answered faster. the gauge display i think had some bugs in it and this could be one of them. why are you using the gauge dispaly?
Old Aug 22, 2006 | 12:24 AM
APD*98SS's Avatar
Yes it's HP Tuners, and I use it for reference while driving
Old Aug 22, 2006 | 12:26 AM
kamikazematt's Avatar
i dont use the 2 bar map but wouldnt you have to add a different PID on your primary table and then set the gauge up to use that?
Old Aug 22, 2006 | 12:29 AM
APD*98SS's Avatar
Acording to HPT, the 1 bar is automatically reconfigured with the 2 bar option; so I just extended the scale to read 210kpa instead of 105kpa, hopefully that will work???
