Options
Old Aug 28, 2006 | 11:42 AM
SDMForever's Avatar
Default Options
Well guys I am will have my new motor assembled by this friday or so and am going to need a tune. I live in michigan and was wondering what to do. I was originally going to do a mailorder tune but now I am not so sure.
Here are my specs I also am purchasing a fuel pump and injectors.
Hey guys I am just now finishing up my stroker build and was wondering what combo I should do for fuel. I have been told to get a fuel booster and some new injectors.
Here is my setup what do ya guys think:
402 C.I. Engine:
∞ Brand new LS6 block machined .30”
∞ 4 inch Eagle 4340 Crankshaft
∞ 6.125 Eagle 4340 Rods
∞ Mahle 12cc Pistons
∞ Texas Speed Magic Stick V.4 Camshaft (239/242, .649"/.609" 112 LSA)
∞ Speed Pro Bearings
∞ Speed Pro Plasma Moly Rings
∞ Custom 3d Cad Lifters
∞ Katech True Roller Timing Chain
∞ Lingenfelter High Performance Oil Pump
∞ Power Force Crank Pulley
∞ 317 Casting Exhaust Ported Polished Heads
∞ 7.4” Comp Cams Chrome Moly Pushrods
∞ PRC Double Springs (Rated to .660" Lift)
∞ PRC Titanium Retainers
∞ PRC Spring Seats
∞ PRC Seals
∞ MSD Ignition Blaster Coil packs
∞ MSD Ignition 8.5mm Super Conductor Spark Plug Wire
∞ K&N FIPKII Cold Air Intake
∞ Custom Ported and Polished Throttle Body
∞ Flowmaster Full Catback Exhaust system
∞ LPA Custom Computer Tune
∞ SLP Performance Parts Electric Fan Control Switch
also what spark plugs should i use
Old Aug 28, 2006 | 11:54 AM
foff667's Avatar
LS1TECH Sponsor
im not sure what your question is...are you asking us for thoughts on your engine combo? if so wrong forum. Are you asking us what spark plugs you should use? if so wrong forum...if your asking us about tuning there are 2 or 3 stickies at the top that should help.
