question about 98 pcm
Old Aug 30, 2006 | 09:58 AM
edstrokedta's Avatar
Default question about 98 pcm
what is the difference between a 98 pcm and the 99-02 pcm?
Old Aug 30, 2006 | 10:26 AM
horist's Avatar
simple answer... everything
it's a totally different pinout and hardware
similarly a 98 PCM is set to use a different ECT sensor and the gauge cluster in a 98 is setup different than a 99+
Old Aug 30, 2006 | 10:30 AM
is there anyway to put a 2000 pcm in a 98 car with modifications? the reason i ask is that i have an extra 2000 pcm and a 98 car. i was wanting to use hptunners on both cars.
Old Aug 30, 2006 | 11:11 AM
horist's Avatar
well you can use HPT w/both if you get a 98 license... otherwise it is possible to change over to the 2000 PCM but a bit of a pain
you would need a different ECT sensor, Knock Sensors, would have to either rewire or replace the wiring harness (i don't know if the connectors are the same), also not all your gauges would work (temp gauge for example... on a 98 it gets signal from the actual sensor, but 99 sends it on the serial feed from the PCM)
in the end would be cheaper to buy a license for $100 (or if you have a newer HPT cable you may already have free licenses available)
Old Aug 31, 2006 | 07:40 AM
thanks for the info i think i will just get a license like you said.
