a4 pcm on a m6
Old Sep 3, 2006 | 06:00 PM
6-Speed Terror's Avatar
Default a4 pcm on a m6
will the pcm from a auto car work on a standard. my car started to sound like when the coils or spark plugs go out and constanatly misses. everything i check turns out to be fine. i was wondering if for testing purposes like to see if my computer is messed up could i connect the auto ta computer on to my m6 and try to turn it on.
Old Sep 4, 2006 | 08:16 PM
camaroguy26's Avatar
yes but you'll have over a dozen codes, speedometer will be off, and the engine won't run optimal but there's not that much of a difference unless you are going to be driving it much. I ran my A4 computer with my M6 for about a week and it seemed to be alright until you got into high speeds and cruising
