Misfire at cylinder 5.
Old Sep 3, 2006 | 07:05 PM
Firebird!'s Avatar
Default Misfire at cylinder 5.
Hey guys. My 99 firebird v6 started shaking and trew a SES light on a few days ago. I stopped at Autozone and got them to check the code. It showed up as Misfire detected at cylinder 5. About a year ago or so I've changed all the wires and plugs (Bosh Platinum +4) for exactly the same reason (but at a different cylinder I think). So now I took the plug out to look and haven't seen anything wrong with it so I put it back and replaced the wires again. The problem is still there and looks like it comes on only when I give it some throttle and trying to speed up, at idle it works a little rough too. But at around 2000-3000 rpms with a very little throttle just to hold the speed it feels smooth Also I've checked the sparks with inline spark checker and it shows on all the cylinders. So right now I am lost and don't know what else to check. Any Ideas on what else could be wrong there?
Thank You
Firebird!
Old Sep 5, 2006 | 11:01 AM
Firebird!'s Avatar
Anybody?
Old Sep 7, 2006 | 03:10 PM
Firebird!'s Avatar
Replaced the plug - same results - misfire at 5th cylinder
Anyone?
Old Sep 7, 2006 | 03:41 PM
87GMC's Avatar
had the same problem turned out to be a dirty injector
Old Sep 17, 2006 | 07:03 PM
Firebird!'s Avatar
Tried to clean those injectors - put injector cleaner in the fuel (was too lazy to take injector out) tank and about 250 miles on a car - no changes at all. Talked to a few people around here - they said to check the coil. So I switched two coils 5/2 with 3/6 set the SES code again and the problem moved to the third cylinder Got that coil replaced and car runs fine now
Got another question - just curious - one contact on that coil is nice and shiny (actually that is the one that wasn't working) and the other one got pretty brown - do you guys know why did it got that way? Is it something I should worry about? Including a pic:
Thank You
Firebird!
