42# injectors tuning question?
http://www.transamws6.net/HPTuners/injectors.xls
My question is what do I input for the Injector Rated Fuel Pressure and Injector Rated Flow Rate? I was guessing that I would leave it at 43.5 and change to 42.5, but I remember hearing that an LS1 is actually higher than the 42.5#, more like 48.83# or something like that. Is this correct, and if it is why does it higher then the inj specify?
Thanks
Nkz
Example. If you were using Ford SVO 42's then you would enter 42 for injector rating, 43.5 for rated pressure and 58 for our fuel pressure.
the Delphi Lucas injectors i bought show a data sheet on the website.
www.racetronix.com (then click 42# injectors on right) scroll down and see the info.
if you notice they show the rating at 43.5psi and at 58psi
attached is an excel sheet that i made to help on the IFR table.
if you put 43.5psi as your fuel pressure
then 58psi as your actual fuel pressure
and put in 42.5# injectors
it will come out perfect.
now, if you want to put 58psi as your fuel pressure
you will have to put 58 as your actual
and then change the injectors to what they are rated at at 58psi
Thanks also to RedHardSupra for all the extra help.
Thanks again,
Nkz
every other change will throw it off. granted, there's enough differences between injectors themselves that there's gotta be some 'slack tolerance' (that's why we have fuel trims) but you're supposed to be helping it with good hardware, not confuse it some more and hope it works it out
