question about wot multiplyer
Trust me, I'm not sitting here telling anyone what they should or shouldnt do. My method works for me and thats all I'm concerned about. I could sit here and make fun of people for spending months on a tune and their car still runs like **** but I wont, its your car do what you will. What I'm doing works just fine for what I'm doing. Would I do this on a turbo car with a boost controller? nope. Would I do it for someone else and turn them loose with a 1000hp street car that drives from 50 to 5000' elevation? nope. I am not selling anything or endorsing anyones product either, just making a simple statement that it works for me and all of a sudden I'm too stupid to add
Its a good thing you guys never had to deal with big carbs lol, you would have had a stroke by now with all that gas just dumping in there like a garden hose with nothing but four drilled holes doing most the metering
i try to use math to demonstrate that this isn't just my opinion, all this stuff stems directly from simple physics. on this board hype and popular opinion matters more than laws of nature--and that's what pisses me off.
I had a similar uphill battle with injectors, and finally convinced enough people why and what they need to run smooth and safe. FI tuning is the same case, just bigger and harder to explain, by the very nature of FI.
yeahh..... I have dealt with big carbs... actually have 2 holleys on a megablower sitting in my street rod. Notice how many carbe'd cars are being produced in 2006. Need I say more??? The technology is old, concept is the same. As far as the attacks go, you are the only one calling anybody stupid. Maybe just maybe you should acknowledge someone else's point, you dont have to agree but thats what this board is for. i try to use math to demonstrate that this isn't just my opinion, all this stuff stems directly from simple physics. on this board hype and popular opinion matters more than laws of nature--and that's what pisses me off.
The math is obvious, I have a BS in computer science back from when it was a real science major so it was 90% math, I can add pretty well if I need to
I wont necessarily discourage people from trying it though, it all depends what they are doing with the car. It seems to be a touchy subject for no reason really, if you know what you are doing it works, but pretty much if you know what you are doing you can make anything work. I look at results and consistancy and the least amount of time spent to acheive a goal, simple as that. I'd also be willing to bet that the BS3 laying on the floor wont make the car run one bit quicker - except for getting rid of ~50lbs of stock wiring anyhow
I never said anyone else's method WONT work, if I did point that out. All I said is what I do works for me, simple as that. There is more then one way to tune these things that work, just because I dont subscribe to your method doesnt make yours wrong and vice versa. I think you should read my replies a little more carefully though, never once did I say it was stupid to do something the right way.
As far as carbed cars I have dealt with them for over 25 years and still do, simple but effective - just like a PE tune
Something else that is simple yet effective is cheating. Hmm... what does all of this have in common?
Honestly I dont care if you want to guess at your PE table and go strictly of AFR. Thats your deal, I just think this "guessing" mindset is accepted to easily, a little more work and its done right. I hope Professional tuners dont take the same stand that you do.
I can honestly care less what professional tuners do to be blunt, this is a do it yourself site (or at least it used to be anyhow) and that has no bearing on anything in this thread. If a 'pro' tuner uses my methods for doing anything then they are most likely in trouble - no argument there.
Cheating?, thats fine if thats what you want to call it. I can guess with the best of them too I'll admit, right down to .01 or so in the 1/4 mile
You can up the fuel pressure to make 60s work just fine if you have enough pump and line. Some injectors work better at high duty cycle/pressures then others though. Problem with upping the pressure is as pressure goes up volume goes down with most pumps. Lot of guys boost reference their regulator and set their base pressure at 60psi but dont realize their fuel system wont handle 72psi @ 65lb/hr at .6 BSFC and the car leans out up top.
Mototrons are my friend...60lb at 43psi, 70lb at 58psi, 85lb at 87psi....better bring a pump(s) to the party though...
I even tune with altering fuel pressure at the track for DA changes (gasp!)...easier turning a screw (loved my quadrajet) to drop psi than reloading an EFI Live file.
BTW, stupid is using EQ Ratio instead of Lambda in PE
The PCM uses the EQ ratio, regardless of what your tuning software displays it as....
Ryan
I'm just kidding Kevin.
Seems like I'm the only one using lambda...it's easier for me since my wideband reads lambda and you know 1.0 = 14.67 Less than 1.0 is richer, greater than 1.0 is leaner...pretty intuitive way to tune, but not popular.
