afr behind cat, look lean to u........
Old Sep 8, 2006 | 05:30 PM
zrater's Avatar
Default afr behind cat, look lean to u........
afr behind cat, leaner bank,
im seeing 930-934 at wot at 5200 rpm, and seeing 13.6 behind cat.
how far do u scale for behind cat like .05 or what.. and would
it be better to throw this thing in open loop when doing this or
just let it drop into the pe tables and run open loop.. i thru the
vcm control for open loop and ran it and looked like 12.6 seemed
vary fat behind the cat.. or maby i should quite jacking around
and get it up front in front of cat...
