o2 high voltage (please help)
Well after about a week of it sitting i had the codes ran again and this time it was bank 2 senser 1 high voltage. So i switched the o2s around to see if the code followed and it didnt so the sensers are fine. I ran the wires up to the pcm and it looked fine to me. They are very close the the headers but it has that plastic on em with heat rap. What should i do/look for.
Any input at all is very appreciated.
Dan
A quick test would be to monitor B2S1 voltage with a scantool, then unplug the sensor. If the reading defaults to 450mV, then you have a rich condition. If its does not, then you have a short to voltage.
If its a short to voltage, unplug the PCM connectors and see if they are corroded or full of water.
If its a rich condition, you may have a stuck open injector (hence the misfire). You could raise the fuel rail off the intake and turn the ignition key on and see if any injectors drip/spray fuel (they should not).
Thanks alot for the help SUPRLYZ its greatly appreciated!
Dan
