bad PCM? help
Old Sep 16, 2006 | 03:09 PM
00blownWS6's Avatar
Default bad PCM? help
has anyone ever had a bad pcm(stock) or one that may have been defected somehow? if so, then how did you know. reason i ask is because my car hesitates at light throttle and if i unplug the MAF the car runs perfect, but it does not throw a code. i swapped it out with a known good MAF and it still hesitated. after the last tune i got at EPP the car ran perfect for about a week then the stuttering started. wot is fine. this is the stock MAF by the way. my sig says my major hp adders. any help would be appreciated. thanks
