4l60e tuning
Old Sep 20, 2006 | 09:13 PM
02 BLK WS6's Avatar
Default 4l60e tuning
What all can be done with HP Tuners? Can the extensions of each gear be individually set? I am having the 2-3 shifting problem of banging the rev limiter. Any tuning advise would be appreciated.
Old Sep 20, 2006 | 09:17 PM
TransAmDrag98's Avatar
if you have strong valve springs. raise the rev limiter farther above your shift points.
Old Sep 20, 2006 | 09:24 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Some loose converters allow too much over shoot so there may be some tweaking to be done. The rpm and mph have to both be met for the pcm to command a shift. I would recommend dropping the WOT shift tables at least 5 mph and drop the rpm 400rpm and work your way up. Make sure the fluid level is right and you can raise the rev limiter as much as you feel comfortable with. You do need a 400-500 rpm cushion between the shift rpm and the rev limiter rpm because there is always over shoot or delay.
Good luck! I hope this helps.
