changing a 98 computer car to a 99+
Al
I look forward to seeing it, if you don't mind sharing the file before it is posted, could I see a copy Ryan212@aol.com
I want to do this swap, and know there has to be a way to do it without changing the cluster and tank.
Thanks
Ryan
Seriously, will all due respect, how do you change the parameters in the cal file? I can see altering the data in the parameters. 98 has 15.5 steel tank and 99+up has bigger plastic tank thus, the parameters are different. Are you doing a ratio scaling of the values? I am interested as everybody else is. My hat is off to you for figuring this out. I guess I was just in a hurry to get things done and didn't think that hard about it. As I was already swapping the rear and I thought What the hell swap the tank and upgrade the pump and wiring too. I am all for making these swaps as easy as possible for 98 owners. There are myriad of reasons to upgrade to later operating systems.
Ryan
