ABS IND light on after dyno...
Old Sep 23, 2006 | 05:14 AM
andypz28's Avatar
Default ABS IND light on after dyno...
ABS IND light in the bottom left turned on after i got dyno'd today.
did they disconnect something or mess with anything?
how can i fix this?
Old Sep 23, 2006 | 06:19 AM
The Reapar's Avatar
how can i fix this?
The ABS INOP light, brake light, and TCS lights usually always come on when you dyno because the rear wheels are moving and the front are not. They also usually go away after a few miles of driving after the dyno.
If they dont go off, check the axle tubes/area. Generally dynos use straps around the axles tubes to tie the car down and its possible they have just pulled on some wiring and pulled a connector loose.
Charles
