Getting professional Dynotune, what do I need to look for??
Shaun Farmer
Your tuner will undoubtalby use a wideband O2 sensor to tune your car. Do you have a bung in place for him to put it in the exhaust stream? They can remove one of your front O2s and go that route. If at all possible if you could have a bung welded in, in spot where both banks could be read that would be optimal but not absoutely necessary. Ask what kind of software they are going to use? If either HP Tuners or EFI Live, do they have the respective Real Time Tuning options for either suite? You should get time on the dyno and time on the road for a complete tune. Drivability- cold startups, hot starts, etc. take time and heat cycles, be leary if they just want to get you in and out the door real quick. I am sure you have better luck than most considering you are in the state where the girls are the fairest and the guys are the squarest- I was born, raised, and went to the University of Nebraska. Where are you having it tuned? Good luck.
