need help with lm1 and efilive
now i just need to figure out how to scan with the wideband 02
right now i have the brown wire in the middle of the red and white wires when hooked up to the dongle... is that even right?
any steps or help would be great.
Go to EFI lives site and look at the documents area. There is a tutorial on how to set it up.
In order to see the WB you need to select the correct pids. Make sure you know which of the dongle pins is EXT1 or EXT2. EFI Live has the LM1 pid already you just need to select it from the list. The tutorial will answer all of your questions.
Howard
hmmm... once i get my Roadrunner in i'll start the car... i didnt want to start the car with the injectors being out of tune with the car and the FP not being right... ill let yall know tomorrow night when i get the rest of my stuff in..
Thanks,
Tyler
Red on the left
Brown in the middle
White on the right
This will give you the WBO2 signal on the EXT.AD1 and LM1-1 pids in the scanner.
