TPS reset
Old Oct 6, 2006 | 07:52 AM
speedracer5532's Avatar
Default TPS reset
I have noticed that when my car is idling the throttle position is 0.4% which is causing issues with my idle. I think with the TPS reading 0.4% the car thinks the pedal has been depressed so then the car isn't using the idle tables anymore. I have done the TPS reset. (unplug the TPS, turn key on for about a minute, then plug the TPS back in) With the car not running the TPS reads 0% but when I start it it reads 0.4%. I have filed the holes in the TPS to give me more adjustment.
Is there any setting in the tune that I can change to say anytime the TPS is less than 1% then the PCM should think the car is idling? If not then what are your suggestions for me?
