Help car wont start.
Old Oct 9, 2006 | 10:18 AM
81z/28's Avatar
Default Help car wont start.
Just got back from 200 mile drive last night and everything went fine. This morning when I turned the key car wont turn over. All the electrical stuff works and it shows good voltage. What should I look at first?
BTW the car is a stock 00 z/28
Old Oct 9, 2006 | 11:00 AM
brad8266's Avatar
Check fuses first. Could be a dead fuel pump or dead ignition system. Does the engine turn when you turn the key?
Old Oct 9, 2006 | 11:06 AM
81z/28's Avatar
I hear the fuel pump.
Its gotta be something with ignition. Everything electrical works but it dosn't turn.
Old Oct 9, 2006 | 01:06 PM
ringram's Avatar
Could be loads of stuff like the soloniod on the starter motor? You can sometimes short the terminals with a screwdriver. With ign on. Likely a fuse as mentioned or a dodgy connection somewhere.
Old Oct 9, 2006 | 07:54 PM
81z/28's Avatar
Ok all the fuses look good and I replaced the ignition relay and still nothing.
What should I troubleshoot next and how?
Old Oct 9, 2006 | 09:05 PM
81z/28's Avatar
Ok turns out the security light is flashing when I hold the key in on position. Im pretty sure the car wont start due to a security issue. I tried replacing the starter and ignition relays and all fuses look fine.
What to do?
Old Oct 9, 2006 | 09:26 PM
brad8266's Avatar
Its your security system. try hitting the unlock button on the remote first and then clean the little chip on the key off. That worked a few times for me.
Old Oct 9, 2006 | 10:03 PM
81z/28's Avatar
looks like im waking up early to dissable the VATS in the morning
