Lt1 Edit Help Please!!
Old Oct 30, 2006 | 03:08 PM
87Lt1Monte's Avatar
Default Lt1 Edit Help Please!!
I just got done dyno testing my currect setup and it was a little lean through out the whole run around 14 what is the easiest way to richen it up a little bit? Could i bump up the fuel pressure or would i have to change pulse rates? No clue need some help. with currect setup Passing MD Emissions a couple weeks before no change 360 HP and 412 ftlbs .. Thanks in advance for help fellas.
Old Oct 30, 2006 | 03:18 PM
SSpdDmon's Avatar
You'll have to forgive me since I don't know LT1 software...but, do you have a PE table? I would think that would be the easiest place to increase WOT fueling if you do. How's the rest of the fueling look (non-WOT)??
Old Oct 30, 2006 | 03:22 PM
brad8266's Avatar
Easiest thing to do is just scale the PE table up a percentage relative to how much of a percentage increase of AFR you want.
