Tuning Question. Before and After. Why the difference?
Old Oct 31, 2006 | 10:11 AM
Chalky's Avatar
Default Tuning Question. Before and After. Why the difference?
I have a stock and modified tun. Can anyone explain what following changes would do for performance?
B0201 "AIR Pump on Time" 51.2703 "CAL: 0 <-> ALT: 210"
B0202 "AIR Pump Startup Delay" -97.6577 "CAL: 400 <-> ALT: 0"
B0203 "AIR Pump Coolant Temp Disable"-82.1142"CAL: 280 <-> ALT: 14"
B0204 "AIR Pump RPM Disable Threshold"18.1643"CAL: 500 <-> ALT: 2825"
B0205 "AIR Pump RPM Disable Timer" 1.1963 "CAL: 0 <-> ALT: 5"
B0206 "AIR Pump Turn On Delay" -97.6333 "CAL: 400 <-> ALT: 0"
B3610 "PE Delay RPM Bypass" 39.0631 "CAL: 500 <-> ALT: 5500"
B3613 "PE MAP Threshold" 1.6059 "CAL: 4 <-> ALT: 4"
B3644 "PE Commanded Fuel Ramp In Rate" -0.0015 "CAL: 0.012500 <-> ALT: 0.006250"
B3616 "Normal PE Mode Enable" 20.4492 "Different from row 0 to row 18 inclusive."
B5910 "Spark ECT Table" -13.3301 "Different from cell: 2,18 to cell: 8,23 inclusive."
B5911 "Spark IAT Table" -6.6650 "Different from cell: 4,9 to cell: 28,20 inclusive."
B6001 "Spark Dwell Time" -0.4711 "Different from cell: 8,0 to cell: 26,20 inclusive."
Old Oct 31, 2006 | 10:44 AM
SSpdDmon's Avatar
Don't know why the dwell time was messed with. The IAT/ECT tables are adders/subrtacters to the final commanded spark. Zeroing these out increases the risk of KR (IAT) or may have been required for better cold starts (ECT). The PE enable should be at or below stock settings. Otherwise, PE might not come on soon enough (higher loads + stoich AFR can cause KR). The AIR pump was simply removed/disabled.
