Hp Tuners Timing?
Old Nov 1, 2006 | 09:21 PM
2002ws-6's Avatar
Default Hp Tuners Timing?
The timing numbers are they total timing or numbers over a stock setting? I just had my STS turbo car dyno tuned and they said they could only run 10* timing. Is that 10* total, or would that be 10* over what the base timing is. Cause I'm a little old school. Idle 10*, then WOT by 3500rpm 25-30*. I've heard others running STS with nearly 18*-22* timing.
Old Nov 1, 2006 | 09:24 PM
Sean Collins's Avatar
The know it all's know it all
total timming there isn't really any base timming unless you move the crank sensors relative to the crank. if its says 10btdc then its 10btdc.
Old Nov 1, 2006 | 10:33 PM
SSpdDmon's Avatar
I find it hard to believe they could only run 10* on 6.5psi of intercooled boost.
Old Nov 1, 2006 | 11:26 PM
2002ws-6's Avatar
See thats what I thought My intake temps where barely above ambient, it was like 75* out that night. Plugs are tr-6 gapped .035. Chevron 91 octane the same gas I've always used. Could the knock sensors have picked up false knock. Some others said you could de-sensitize them while on the Dyno. IF I was really running 10* how much more power would I be looking at with say 18-22*? I mean 425 and 465tq at 6.5 lbs STS doesn't seem to bad especialy on a dynapack dyno. I think I'm gonna have them re-tune it once I get my 2-bar map sensor. It was late we got off the dyno at 2 am after starting at 6pm so I was tired but I remember seeing timing as low at 1and 2*. Why would you ever run that low of timing? Whats weird too was the tuner showed me another guys turbo LS2 GTO running 22* timing putting 550 to the wheels.
Old Nov 2, 2006 | 08:46 AM
dynocar's Avatar
If I were the tuner and you were getting a lot of knock retard I would have done the same thing, error on the safe side, unless I had the time and the customer had the money to further diagnose it. One of many possibilities, could be fuel, according to some fuel transport drivers I know, BP's 92 octane isn't always BP 92 octane now days.
Old Nov 7, 2006 | 12:55 PM
tinytimsolderbrother's Avatar
Default I had the same problem
with 91 octane and 6 psi I would recomend you use alky injection!
my car with 5 psi ran 15-16 degrees of timing no problem
bump it up to 6 and it starts showing knock retard requests
like crazy. on a much cooler day 55 degrees I ran 6psi and it
would stay around 14-15 on a hotter day 80 it would start dropping
to 12-10 put meth in jection on with 6psi and it stays at 15- 16
all day long. I keep it at 5 psi and dont use alkly/meth injection
currently and its been fine!
also make sure those damn screwon tips are tight! on your plugs
I had issuses with timing and it turned out 3 plugs had loose tips.
the other guy above has a point is the 91 octane your running
actually 91 yah never really know!
I would use alky injection with that level of boost just as a safe guard!
