TPS sensor reading
Old Nov 9, 2006 | 08:37 PM
Kounsy's Avatar
Default TPS sensor reading
When the hp tuners is on my car, the tps reads 0 to 1% and it idles fine but then all of the sudden the tps will read 2% and it will bog down and try to dye. Does anyone know about this situation?
Old Nov 10, 2006 | 06:46 AM
LS1-450's Avatar
've seen this happen when the MAP sensor receives a low input or a no input voltage on my 98. For some reason the low MAP input causes the TPS to go to 2% & bog. May be something else, but, I'd check for a MAP code.
