TunerCat Probs + Others
But anyways I am new to the tuning part. I have TC and Datamaster. When im logging, im loosing connection every 10 sec. Im also recording 128MPH at Idle. Also throwing about 10-15 diferent codes at differnet time. Mostly 43 & 48.
Also not exactly sure how to work with TunerCat but it wont read the PCM. Any tips what do I need to do?
I think i know what happened here. You are working on a 94-95 just by the code your getting i know that much. Did you use the correct Definition file for you pcm when you editied it then flashed it back in? there is EE and EEB and some of the data areas get mixed up when using the wrong def file.. if not you could be having a crap load of file related errors. Email me a copy of the file you modified i will check it over for you. If its the wrong file or corupted i can email you a fresh starting copy. collinsautomotive@sbcglobal.net Also try emailing tunercat as well. they should have those files on hand.
I have a 96 formula converted to a OBD1 out of either a 94 or 95 camaro.
http://www.aldlcable.com/sc/details.asp?item=aldlobd2u
