Tuning Larger Injectors
Old Nov 10, 2006 | 04:29 PM
Brett H's Avatar
Default Tuning Larger Injectors
I am likely going to need to replace my stock 26# injectors with new 36# or 42# ones to allow me to run a 100hp dry shot safely.
My question is, with regards to tuning them in HPT, the only table I can seem to see that I need to change is the Engine/Fuel Control/General Fuel/Injector Control/Flow Rate vs. KPA. Is that the only table or is there more to it? I have been told I may need to scale new injectors and also modify the pulse widths to keep idle and part throttle from going fat.
Also, while I was doing searches I read a few times that there is a chart that will help with changing the values in the tables properly. Does anyone know where I can find that?
Old Nov 10, 2006 | 04:59 PM
Doc's Avatar
Doc
Dude, stickies...
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
It is all there
Old Nov 10, 2006 | 11:00 PM
Brett H's Avatar
Thanks man and sorry I didn't even think to look in the stickies. I did a couple key word searches and didn't get what I needed.
