New to tuning
Try to get on a dyno for your WOT runs it is much safer than logging on the streets and you can see if your helping or hurting it.
Most shops will have a reduced price on Dyno time if you have your own software and they arent doing the tuning.
Good luck!
Brent
What i did was first set the PE vs RPm table to what i want to command at WOT. The you can tune the VE table in order to get your Long term Fuel trims close to Zero. Once you are close to zero then you can move onto really dialing the VE table in at WOT. You can then also add timing if you want as well, go up until you detect knock, then either back off a degree or add some fuel.
With the cam you will surely need to go a good idel tune which involves setting the idle speed as well as other values such as throttle cracker.
Do a lot of searching around here and you will find lots of great information. i learned how to tune using LS1 Edit just by reading everything i could here and then actually doing it step by step myself. Always keep a copy of your stock tune so that if you mess up bad you can just revert back to the original tune.
The best thing to learn in order to know what changes in the tune do what is to first learn how the cars PCm works and what sensors do what in order to adjust fueling and spark, ect ...
happy Tuning man.
