Need help with VE and Timing Tables-TEC3
It runs on 100 unleaded, and is managed by a TEC3r. I have the IAC running and an AEM UEGO running and plumbed into the TEC.
I am hoping someone might have a similar setup and could share with me their VE and Spark tables. I would assume tables from any tuner would work as a good guideline, but I havent been able to track anything down yet. Thanks!!
My primary problem was related to idle, and I was convinced that I had something in one of the tables off. I smoke tested it today to make sure there were no vacuum leaks and there were none. HOWEVER, I yanked the intake to check for IAC function and the damn thing isnt fully extending, so its bleeding air and the idle is sitting at 2k. Worked fine last week...oh well, at least I know!
