NEWBIE DFi questions
1) Is it reliable, on the street everyday. i heard you have to rid the stock ecm...
2)do i retain the wiring harness?
3)does it know that my 95 t/a doesnt have an LT1 in it anymore? now an Ls2
4)is it good to use for a 2 bar SD, on a Turbo stroker?
5) which one do i go with? the bs3? the fast? ...
if you wanna throw some things in please do... i am in need of this info to continue my project... thanks guys
**I doubt much of the harness will work, due to totally different engine operating system.
**Any system you install, will know only what you set it up for. The base system must be purchased w/ the correct harness, and sensors, for the engine.
** Again, you will have to program the system to recognize the sensor, 1, 2,3 ,4 bars.. The ECM does only what you tell it to.
** I've used the FAST, and the Accel GEN7+. Both systems have good features.. some not so good. I'd suggest a search on the BS3, and draw your own conclusions.
