Need help on 2000 chevy pickup
Before they have you blowing thousands...give me some background on the vehicle...'00 Chevy truck 5.3?, when did this happen, have you had any programming changed (tuning), is there a service engine soon light on. If so, scan the codes with the purchase of a walmart scan tool or take it to autozone for a free scan. See if the codes are set for ignition related components. If you have a Haynes/Chiltons manual or a friend with some automotive know how...get him to check for a reference signal from the plug on coil pack. ALSO.....check all grounds and connections on the individual coil packs and the main harness that is located at the center of the coil pack bracket...give them a quick wiggle. I figure if you getting carbon fouling...your getting fuel. Plugs are the cheapest....you've replaced the coils....the next thing inline is the connections and the reference signal. I would recommend NOT going back to that shop again...that's rediculous...places like that make me want to
To many crooked shops now days
Thanks
Test it from the coil to where the harness meets the other coils...(a rectangle connector about 1.5x.75in. in the center of the coil bracket assembly). Then if the wires check good there....move on from the coil bracket harness to the PCM pinout block...(I think it's the lower large 80 pin connector)...if you hold the PCM connector towards you with the 3 bumps on the bottom...(so you can't intall it upside down)...the pins are numbered from RIGHT to left 1-20 and 21-40 (Top row) and 41-60 and 61-80 (Bottom row). It's kind of goofy but hey Just remeber RIGHT to LEFT
The pins are the IC Control outputs....the pin for #7 Coil is (27) (top left row) which has a RED Wire.....and the pin for #8 Coil is (66) (bottom left row) Purple/White. After you do this mess....and nothing is shorted...it will probably be the PCM. If you have a buddy with the same kind of truck/motor from 2000+ you could just swap PCM's. I hope this helps
Chris
Chris
