Wideband users: which setup will do this?
Old Nov 30, 2006 | 10:18 AM
RW99's Avatar
Question Wideband users: which setup will do this?
Had this posted in the FI section, and nobody answered...
I'd like to have a shiftlight that will illuminate when:
1. AFR goes past 12.5
--AND--
2. MAP is showing xx boost. --or-- revs exceed xx rpm. --or-- WOT
Is there a simple way to set up an LM-1 to do this without rigging some sort of custom electricals? Or is there another wideband that I should consider? Or alternative "warning" setups?
I like the XD gauge, but I'm concerned that I won't notice a lean condition on it.
Thanks in advance for any help,
Rich
Old Nov 30, 2006 | 10:21 AM
foff667's Avatar
LS1TECH Sponsor
not sure if the lm1 by itself can do it...I know with hptuners pro version you could rig something up just by using the analog outputs as explained here http://www.hptuners.com/help/vcm_sca...connecting.htm
Old Nov 30, 2006 | 12:05 PM
koolaid_kid's Avatar
According to Innovate, you can use the "LMA-3 (AuxBox) input Expander Cable. The AuxBox will give you the choice of picking sensors existing from the vehicle or use the 5 internal sensors. The five internal sensors are: RPM conversion (from a tach signal or inductive clamp), Manifold Air Pressure (MAP or Boost), Cylinder Head Temperature (CHT) or Exhaust Gas Temperature (EGT), Acceleration, and Injector Duty Cycle (Dwell)."
It does cost more money, and I have not used it myself.
Hope this helps.
Old Dec 2, 2006 | 03:15 AM
Blackbird's Avatar
the dynojet one will do it out of the box
Old Dec 2, 2006 | 08:08 AM
cablebandit's Avatar
bingo
my DJ-WB light comes on if it is leaner than 12.0 over 4000 rpms
Old Dec 4, 2006 | 09:34 AM
RW99's Avatar
Thanks guys... just the info I was looking for. But will the WBCommander trigger an external light?
Cablebandit, do you feel that the WBCommander's warning light (I assume it's on the gauge somewhere) is sufficiently bright that you actually notice it during the daytime?
Old Dec 4, 2006 | 12:50 PM
Blackbird's Avatar
it will trigger whatever you want.
no warning light on the guage if I remember correctly. just outputs for you to connect it to whatever you desire, light, buzzer, etc...
