Can someone with a clue HELP
TIA
b. your rev limiter is set at 7000 rpms
c. shift point set at 5900 rpms & 66mph for 2-3 shift with 3.72 gears yes 3.72 tire height of 24.9
do you have a log where you actually go over say 6400 rpms?
I know, it wont let me go. I hold the gas to the floor and at ~6k I get this second or two studder then it shifts into the next gear.
I had a "pro" tune this before I bought hpt and thats what he had in there for the gear. Thought that was maybe the 3.72 was "offical" size of the gear, not sure. I Will change that though.
Is that the right size tire? I have the 16" stockers on it.
Thanks
Like I said before, I had someone else "tune" this before I began messing with it. I did not like how it ran and knew I would be getting more mods so I decided to get hpt and learn for myself.
So you think I should just "disable" the shift lock? I did not see any speed/rpm adjustments that would make that hold at 6k though.
