Got a weird problem.
Old Dec 21, 2006 | 10:44 AM
HossZ28's Avatar
Default Got a weird problem.
When the engine is cold it starts fine, but every once in a while when it in is warm all it does is turn over but it wont start. I let it set for a second or two and try again, it starts fine. I am not sure if it is the spark plug or timing. Plugs are original (60k miles) and I have a predator. I need help because this is starting to get annoying.
Old Dec 21, 2006 | 11:11 AM
Sean Collins's Avatar
The know it all's know it all
Put a fuel pressure guage on it and see if its holding pressure at least 30 psi and make sure the priming pressure is 50-60 psi.
