Upgrading Injectors
Old Dec 23, 2006 | 11:32 AM
Brett H's Avatar
Default Upgrading Injectors
I am currently running stock 26# injectors and they are running more than 100% DC, or what I think is referred to as "static" with a dry shot.
I can get a set of stock '02 28# injectors for free so for the time it takes to swap them I figured its worth trying them to see if they help.
So my question is, can I just take a stock tune from an '02 and use its injector tables and scaling and paste them into my '99 pcm? (I have HPT)
I have searched and read threads about using the charts and spreadsheets to come up with the correct values on large injector replacement but I was hoping just doing a copy and paste would work for me just to see if the 28's help before I spend a lot of time on it because if I still run static I will just buy 36 #'ers and then spend the time scaling injector tables.
Old Dec 23, 2006 | 01:34 PM
foff667's Avatar
LS1TECH Sponsor
yeah that should get you pretty close, some final tweaking will probably be needed though.
