IAC counts (V2 EFI Live)
Old Jan 3, 2007 | 01:12 PM
LSs1Power's Avatar
Default IAC counts (V2 EFI Live)
I tried the IAC steps (GM.IAC), but its not working for some reason... Which pid shows the IAC counts?
Thanks
Old Jan 3, 2007 | 01:14 PM
SSpdDmon's Avatar
Mmmmm....boost.
Sorry for drooling over your sig.
Old Jan 3, 2007 | 01:31 PM
Tordne's Avatar
GM.IAC shows the number of steps, found under the 'Air' section in the PID list.
Edit: Pressed wrong button LOL.. Is your car cable or electronic throttle?
Old Jan 3, 2007 | 01:43 PM
LSs1Power's Avatar
I know... I need the IAC counts not steps. I was to check my counts to see if im close to 40 because my car is struggeling to idle. It is Cable.
Old Jan 3, 2007 | 01:47 PM
SSpdDmon's Avatar
counts=steps You want them @ 50~60 when the motor is warm.
Old Jan 3, 2007 | 01:51 PM
LSs1Power's Avatar
So why does my IAC steps has a disabled line on it?
Old Jan 3, 2007 | 02:40 PM
wait4me's Avatar
is it selected in your Pid tab? If your right click on that properties tab it will tell you why it has a line thru it.
Old Jan 3, 2007 | 02:47 PM
LSs1Power's Avatar
In the log file it self it says its not a valid selection, but when i Open the Scan software with no logs loaded it show IAC with no line thru it.
Old Jan 3, 2007 | 02:55 PM
wait4me's Avatar
Have you validated the pids?
Old Jan 5, 2007 | 02:26 AM
LSs1Power's Avatar
Yes.... For some reason everytime i open the old logs it switchs the pids around which is why i get the thru line through the pids.... So now everytime im done looking at an old log i shut down the scan tool and open it again so it can load my pids or I can just load it up from the load option in the tabs. When loading up the pids i want... i have to make sure that i load the A and B to make sure they match. I think that was the confusion.
Old Jan 5, 2007 | 02:28 AM
LSs1Power's Avatar
The best we could do with the counts or steps is 80-90.... So we drilled a larger hole in the TB and that helped a bit.
Old Jan 5, 2007 | 04:06 AM
Black02SS's Avatar
I think I would have left them at 80-90. How did the car run with them there compared to where it is now?
Old Jan 5, 2007 | 11:16 AM
LSs1Power's Avatar
Slightly better, but i never logged the IAC steps after the 1/4" whole... We just called it a night. We might dyno the car today N/A to see where its at before we bolt the SC to it.
The strange thing is that the 408 requires less VE to idle than the 346 needed. I thought it would be the opposite, but i think its due to the low compression of 8.4:1 of this 408.
