Scanmaster #'s
Old Jan 6, 2007 | 12:25 PM
BlueSLPCamaro's Avatar
Default Scanmaster #'s
Does anyone know what the baseline/idle values of the LS1 scanmaster(2002 Camaro) readings should be as well as cruising and WOT. My brother has the scanmaster in his GN and he has all these values for his scanmaster.
I searched the web and I found LT1 but no LS1 numbers.
ATS(IAT) Intake Air Temp
MAP
BAR Barometric Pressure
TPP Throttle Position Percent
LO2/RO2 Left and Right O2 Sensors
LP/RP Left and Right Injector Pulse Width
CCP Carbon Canister Pressure
SP Spark Timing
Knock/Retard Max Value
LIN/RIN Left and Right Intergrator
CEL Fuel Cell, Long Term Fuel Correction
MAF
EGR %
Mal/DTC Malfuction Codes
Old Jan 6, 2007 | 10:51 PM
02SS3098's Avatar
For all the DTC codes you can go to http://www.obd-codes.com/trouble_codes/index.php
