mojofinger needs advice
Old Jan 6, 2007 | 07:27 PM
mojofinger's Avatar
Question mojofinger needs advice
can i get a stock computer that has only the data to run the engine.If so will it work on a low boost (8-15psi)application if i use a boost a pump or a extra injector.I'm not looking for every hp i can get just about 650 reliably. i'm using a 5.3 with upgraded pistons& rods.
Old Jan 7, 2007 | 02:53 AM
Doc's Avatar
Doc
Elaborate on your application...Make, model, function,(ie street/strip, strip only), custom gages, etc. You are at a clover in the road with this question.
Old Jan 7, 2007 | 09:15 AM
mojofinger's Avatar
Default mojofinger needs advice
I have a datsun 260z that weighs 2450 that I'm putting the engine in.It is a street strip setup kinda spartan interior but i still want to be adle to drive it to the track. I'm lookin at a 76mm turbo with a methanol injection setup.I'm tryin to keep the C/R around 8-8.5 to one. That should be easy to keep streetable.I have a built turbo350 with a 3000stall converter 9in. ford rear end with 3.55 gears. The only thing I really need the computer to do is manage the fuel and ignition.I thought about the megasquirt it seems to be a bargain but we all know how a bargain can bite you sometimes.If anyone knows where I can get more info on the megasquirt let me know .THANKS
Old Jan 7, 2007 | 11:44 AM
Doc's Avatar
Doc
What kind of instrumentation do you want to run?
Old Jan 7, 2007 | 07:47 PM
mojofinger's Avatar
nothing fancy as far as gages tach. manual boost guage. manual oil pressure manual water temp. just the basics
