PCM Power Source Loose
Old Jan 8, 2007 | 08:50 PM
FLA02TA's Avatar
Default PCM Power Source Loose
When I hooked up my AutoTrix kit to the power source near the fuse boxes, I didn't tighten it enough I guess. My car was completely dead when I was leaving bowling league just now. Jump start did nothing, and as I was fiddling with the red cover on it, the person with me turned the car over.
It bogged bad but eventually came to.
As I was driving home, the car was almost dying on bumps and my entire light panel was going crazy. So when I got home, my common sense told me to check that nut.
Turns out it was loose. Car works perfect now. What a scare, haha..
I guess my question is, do I need to re-run my VHP handheld if that happened?
Also, that nut doesn't seem to go too tight without fear of over-torquing it. The plastic under it doesn't give good leverage.. is there something I can use that will help that?
Thanks
Old Jan 8, 2007 | 09:34 PM
2001NBMZ28's Avatar
Don't know about the Auto Trix thing, but whatever VHP tune was in the car should be fine.
