exhaust changing tune
Old Jan 11, 2007 | 10:53 AM
dlc1609's Avatar
Default exhaust changing tune
are there any potential tune problems running a stock catback most of the time and then running a cutout open when i'm gonna really do some dragging. don't have a wideband yet so i haven't been able to check how much afr changes. does the computer compensate enough for this drastic of a back pressure change? and could the stock catback's back pressure hurt motor in any way, or just kill power?
Old Jan 11, 2007 | 12:11 PM
SSpdDmon's Avatar
Anytime the engine breaths better, it will lean out some. Whether you take the air filter out or relieve a restriction in the exhaust, it has the same effect. I took the filter out after a dyno pass and noticed a 0.2~0.4 difference in my recorded AFR on the next run. If your car is tuned to run 12.8-13.0 on the stock exhaust setup, you might want to have it richened up a bit for when you open the cutout.
