Problems with LS1 Edit
Old Jan 11, 2007 | 11:10 PM
HeavyWeight's Avatar
Default Problems with LS1 Edit
Need help bad. My laptop will not connect with my PCM in my car
Old Jan 11, 2007 | 11:19 PM
ls1 joe's Avatar
I have had poblems with the serial port in my laptop. I purchased a USB to serial adapter, and that cleared up my problem.
Old Jan 11, 2007 | 11:22 PM
horist's Avatar
what error message are you getting?
what are the specs of your laptop?
Is this a new problem (used to work now doesn't )?
Old Jan 12, 2007 | 08:20 AM
The guy I bought the car from had it, this is the first time i tried to use it on my laptop.
Old Jan 12, 2007 | 09:51 AM
horist's Avatar
Also does your laptop have a physical serial port or are you using a USB to serial adapter?
Can you connect with the scanner?
Does your cigarette lighter work?
Old Jan 12, 2007 | 10:11 AM
YES
YES
Old Jan 12, 2007 | 10:18 AM
horist's Avatar
is it giving an error code when trying to connect with edit? is the error when doing a read or write? Has the PCM been tuned by someone else in the past (possibility of being locked?) What kind of car? (year, make)
May be an issue with the USB adapter, what brand is it? I don't recall what settings edit wants, but I would assume there'd be something in the help file?
Camaroholic's Avatar
What brand USB to serial adapter? They can be pretty finicky.
 Michael S. Palmer
Old Jan 12, 2007 | 10:42 AM
brad8266's Avatar
Make sure drivers for the adapter are first installed, and then in LS1 Edit change the connection port to use, I think mine connects on COM 3 for my USB connection. I had your same problem till I tried all the different ports.
Old Jan 12, 2007 | 09:37 PM
brad8266's Avatar
Originally Posted by 2002_Z28_Six_Speed
I don't think you have to have any drivers installed to operate a RS232 device.
Go to LS1Program. Connect all cables. Click on the program_PCM tab. Select a program file. Go to the Log_comms tabs and select a file to save it as. When it gets done post the text file up here so we can see the error message.
If it really feel it is a com port problem then I would go into the Device manager in windows and see what settings are on this virtual serial port. Or try a laptop with a dedicated serial port.
You do need drivers if you use a RS232 to USB adapter though.
Old Jan 13, 2007 | 05:47 AM
wyndzer's Avatar
BAFO has the best serial to USB in my opinion.
Old Jan 14, 2007 | 12:14 AM
The error I get is a comm error
The USB adapter is from radio shack
Old Jan 14, 2007 | 01:41 AM
horist's Avatar
HeavyWight: you need to provide some more info! (at least quote whom you're responding to!)
lots of posts here asking questions to help you, but your replys don't address most....
Given your last reply.... I would bet the radio shack USB adapter is to blame.... Radioshack and Belkin USB adapters seem to cause problems.....
if you can connect w/the scanner (as you said you can) but not via the edit tool... it's likely a problem with your USB to serial adapter... try different settings
Old Jan 14, 2007 | 08:04 AM
Steve01SS's Avatar
Check your serial cable from the ls1edit adapter to the laptop. It's like a $5 cable... I had problems connecting in the past when I had ps1edit. Had a bad cable. If you wiggled it it would connect. Got a new one and was good to go.
Old Jan 14, 2007 | 01:54 PM
No the computer say comm error attempting to establish connection with PCM
Is it this error??
PCM LS1 Programmer Version 0.74
03:09:31: <waiting for CTS>. Please make sure RS-232 cable is attached
XMIT: 03:09:31:843: 4,6C,F2,F1,9F,
Disconnected
If it is that then the adapter is to blame.
Old Jan 21, 2007 | 12:05 AM
here is what the error is
File Type: bmp
