EFILive and RoadRunner Specials!!
Old Jan 17, 2007 | 07:34 PM
Black02SS's Avatar
Originally Posted by Tordne
As all you guys/girls get your new RoadRunners (you lucky people), check out THIS THREAD for driver information etc.
Here is more information on this as well.
http://www.moates.net/product_info.p...products_id=66
Old Jan 17, 2007 | 07:59 PM
Tordne's Avatar
The new driver merges both of the previous driver streams
Old Jan 17, 2007 | 08:17 PM
TAQuickness's Avatar
Originally Posted by 1989GTA
Question. I will be converting my 1989 Trans Am to a OBD2 12200411 PCM. It will be flashed with a 2001 Vortec 5.7L Express van program.
Will the RoadRunner support this setup? I know EFILIVE supports it as I will be going that route. Thanks.
If it's the 512kb LS1 PCM, then yes the RR will support it. If not, you'd need to contact a sponsor directly to make sure.
Old Jan 17, 2007 | 09:14 PM
1989GTA's Avatar
Thanks for the reply. I beleive it is as I have just seen on a post where Craig Moates is using the same computer. Will look into it further.
Old Jan 17, 2007 | 09:19 PM
Tordne's Avatar
The 12200411 PCM is the standard LS1 style 512kb PCM. The 512kb RoadRunner replaces that PCM
