Fan Settings
Old Jan 17, 2007 | 11:22 PM
BayAreaSS's Avatar
Default Fan Settings
I would like to know what temperature i should set my fans at? It will be done with hp tuners.
I have a bolton car if it matters
TIA
Old Jan 17, 2007 | 11:29 PM
ChrisS@sdpc's Avatar
You can lower them if you like. If you haven't changed the thermostat, you might not see the results you desire. The stock settings are generally up there. You can try lowering them 10-20* and see how you like that. If you change the thermostat to say a 160 you could try
Fan 1 on 183 off 179
Fan 2 on 187 off 184
or
Low turn on - 195
low turn off - 188
high turn on -205
high turn off -195
See here for some additional advice.
Old Jan 17, 2007 | 11:43 PM
BayAreaSS's Avatar
or
Low turn on - 195
low turn off - 188
high turn on -205
high turn off -195
Thank you.
Old Jan 18, 2007 | 10:25 AM
SSpdDmon's Avatar
I had the stock stat and lowered my high/low on/off temps by 20*F. Never saw it above 217*F after that, whereas before it could get into the 230's on a hot day.
Old Jan 18, 2007 | 10:47 AM
foff667's Avatar
LS1TECH Sponsor
yeah with the stock stat i usually set the turn on's at 200 & 205 respectively.
