Cammed Trailblazer SS
[ECM] P0036 - HO2S Heater Control Circuit Bank 1 Sensor 2 (SES) (Old) (History) (Current) (Immature)
[ECM] P0056 - HO2S Heater Circuit Bank 2 Sensor 2 (SES) (Old) (History) (Current) (Immature)
[ECM] P0141 - HO2S Heater Performance Bank 1 Sensor 2 (SES) (Old) (History) (Current) (Immature)
[ECM] P0161 - HO2S Heater Performance Bank 2 Sensor 2 (SES) (Old) (History) (Current) (Immature)
[ECM] P0300 - Engine Misfire Detected (SES) (Old) (History) (Immature)
It is also having some idle trouble.. I cannot upload the tune because the file is too large.
Cam is a 222/224/566/568-112LSA and the stall is a 3400Vig..
These mods suck ***. I cannot believe I actually paid to have this **** done. Stupid me. btw: I have not adjusted the idle spark advance. Any advice would be appreciated..
the p0300 is just tuning
I've attached two more logs of me trying to get the idle correct. I upped the idle spark advance to match my High Octane table.. also added some to the "Airflow Final Minimum"... Tried to get it running at 800.. Has some trouble starting up. Also wants to drop to ~600 here and there.
My main concern was the timing looked like this /\/\/\/\/\/\ at idle in the previous logs.. I took out some of the overspeed correction too..
What do you think is a realistic target idle for a cam like this?
Thank you for the reply and the diagram. When the car is on the lift I will do some inspecting. If this keeps up, that should be soon.
If anyone feels that a video would help.. Let me know. I have one from yesterday, but since then the idle has been dropped from 1k to 800..
http://69.165.167.234:8192
click webdisk and click temp.. You'll find a video and the hpt file..
Fast98: If you'd like, you can upload your buddies tune to my website and have people download it from there.
Have you taken a look at the tune?
Idle.Timing.Advance.V2.hpt
I put that one up just now.. Thats what I took the latest log with.
What up man?
Now the main tuning problem is that the converter locks and unlocks on the highway.. It'll unlock at the slightest touch of the throttle and then I'll be just cruising and it'll lock up. Feels like an upshift.. The rpms go from say.. 2k to 1.5k or 2.5k to 2k.
Shouldn't the converter lock up past a certain speed and just stay like that? It seems to me like its also relying on TPS/ETC.
For most LSX vehicles, increasing the values in the Misfire tables (in Engine Diagnostics) to the max will get rid of the random lock/unlock problem at cruise. Others with TB SS and high stall TC's have reported similar problems. Seems to related to the 4L70E trans itself, but I can't say for certain. I would at least try to change the values on those tables.
What is exactly is a reluctor wheel. It seems like this is on the end of the crankshaft. When doing a cam install, could this have been screwed with? Definately bummed out.. More down time for me.
Reluctor wheel is on the back if the crank. The only way to screw with it is to drop the pan, etc. During a cam install it doesnt not mess with the wheel.
Its gotta be a ground or short or some ****. What else could throw that code that isn't related to tuning or reluctor wheel issues?
