msd adj. timing control
Old Jan 19, 2007 | 07:00 PM
Taubr Unit's Avatar
Default msd adj. timing control
I got a good deal on a msd 8680 timing controler. It has the external adjuster and it shows you how much advanced you go. But if you turn the **** to full 15deg. then you back off how much you want to retard the timing. Its goin on a '94 lt1 car. I have a 6al box already so i can plug it into that. Anyone use this box at all? And is it compatible with my coil/6al box. Whats the word on this devise.
Old Jan 20, 2007 | 12:06 PM
foggedz's Avatar
I also have a 94 Z28 with the same setup. 6al, blaster coil, and the adjustable timing controll. Everything works great, you just splice it in with the 6al wiring.
