HPTuners: need alittle help getting started
Old Jan 20, 2007 | 01:42 PM
Reject's Avatar
Default HPTuners: need alittle help getting started
as yall have noticed i've been trying to get my feet wet tuning using HPT. i've read the sticky up top showing you how to get started tuning it, but my problem is i cant get the car to stay alive by itself. I was wanting to do the second step on the LS1Tuninginfo.doc up in the stickies. but i'm not able to get the car to stay alive without having to give it some gas, much less trying to move it around to get a 30 minute log. i included the .HPT and the .HPL below so yall could check it out. MS4 cam btw with EGR/AIR delete mod done, those are the only mods done to it (i know i work backwards on mods...i'll get the heads and stuff in a few months, i'm just trying to get the car in the ballpark to run by itself so that i can fine tune it later) anyways thanks for every one that reads
http://reject.sleepingz.com/HPT/Carrie%20stock.hpt 462K
http://reject.sleepingz.com/HPT/stock%20Carrie.hpl 188K
Old Jan 20, 2007 | 02:47 PM
foff667's Avatar
LS1TECH Sponsor
shouldve looked at the idle steps first
heres a starter file i whipped up...should get you at least up and running...your turn from there though.
File Type: hpt
Old Jan 20, 2007 | 02:51 PM
Reject's Avatar
doh!! thank you, how do i download the file? i click it and get a bunch of letters and symbols, again thank you for taking the time
Old Jan 20, 2007 | 02:57 PM
foff667's Avatar
LS1TECH Sponsor
just right click save as then rename it as an .hpt file
Old Jan 20, 2007 | 03:00 PM
Reject's Avatar
thank you i have so much to learn still
