Iat
Old Feb 1, 2007 | 01:07 PM
brad8266's Avatar
Originally Posted by 2xLS1
If you are talking about this table, that is a coolant temp adder. This is version LS1edit 1.5.
Nope i have a thrid one for IAT
foff667's Avatar
LS1TECH Sponsor
if it is in fact an ect pe adder heres a table from an 00
File Type: txt
ectpe.txt (214 Bytes, 69 views)
Old Feb 1, 2007 | 01:08 PM
Frost's Avatar
Yeah, there is a PE vs ECT table.... but shouldn't be the PE vs. IAT...
Old Feb 1, 2007 | 01:09 PM
brad8266's Avatar
maybe it is ECT, if it is then my bad for the
Ill post it up later tonight.
Old Feb 1, 2007 | 01:12 PM
Frost's Avatar
Thanks for looking, I really appreciate it.
Predator, really sorry for the hi-jack... and to really answer your question... I'm nearly 100% sure that at WOT with HIGH IATs you will lose up to a MAX of 3 degress on stock tuning. Since it's so far at the end of the MAP, it should only affect WOT or very heavy throttle. If you are N/A this should hardly be noticeable if at all.
Old Feb 1, 2007 | 05:34 PM
brad8266's Avatar
Well it is IAT like i thought. Attached is a screen shot and here are the values for the adder table. It starts at -40C and goes to 140C in increments of 10C.
-0.1767 0.0001 0.0087 -0.8549 1.0828 0.0000 0.0000 0.0000 0.0004 1.2499 1.1874 0.0000 0.0000 0.0161 0.1805 0.0473 -1.8785 0.2850 0.2800
My IAT MAp table is attached too with the values filled in with a stock PCM.
File Type: doc
File Type: doc
Old Feb 1, 2007 | 06:05 PM
2xLS1's Avatar
Figure out what -40C and 140C are in F and let us know if you still think that table is still referencing air temp.
Old Feb 1, 2007 | 06:15 PM
brad8266's Avatar
How about you just tell me what it is referencing then since apparantly the table is lying to me and you seem to know it all?
The IAT adder table has the same range and increments as the coolant temp adder table does too. I guess the coolant table must be referencing something else too.
Old Feb 1, 2007 | 10:39 PM
Frost's Avatar
The range is the same since both sensors use thermistors that have the same characterisitc curve (in reference to your other last post).
Dude LOOK at those values.... It IS AN ADDER TABLE, and it *MUST* not be active. -1.875???? -0.8549??? +1.24999??? and what the hell kind of curve is that anyway... A HUGE negative number and huge positives randomly stuck around each other... A PE of 1.176 is about 12.5:1 on a properly tuned car. Look at how bad those values would murder the table...
FWIW I have found that moving the PE table beneath 1 ceases to pull fuel at WOT. I have seen it trying to chop out something quick after adding pumps and having lots of rail pressure; and there are values there pulling way beneath 1.0.
Here are some caps from an 00 Z and an 01 TA, the 01 has the table:
Old Feb 2, 2007 | 08:19 AM
brad8266's Avatar
yeah i dont know what the deal is with it with all those values. Im gonna try adjusting it when i get my engine finished and see if its active or not.
Old Feb 2, 2007 | 08:47 AM
warp_6's Avatar
Can anyone else with an 01/02 F-body tune look at the PE vs. IAT table and let me know if it is populated with anything other than zeros? Thanks.
02 all zero's.
Old Feb 2, 2007 | 12:47 PM
  #32
Frost's Avatar
Thanks warp_6.
Brad, I'll be intrested to know what you find.... that table can't possibly be active given it's population
Old Feb 2, 2007 | 01:14 PM
  #33
usd2sing's Avatar
subscribed. great topic!
EDIT: Bill, this is the exact type of thing i was hoping to have put into a future version for the v6 crowd...if possible. (well at least in the 2002 fbody's...hahaha)
Old Feb 2, 2007 | 01:15 PM
  #34
brad8266's Avatar
Thanks warp_6.
Beats me, ill check it out eventually. Its gonna take a few weeks though, I still have to get the new engine in first.
Old Feb 2, 2007 | 02:43 PM
  #35
Frost's Avatar
Oh yeah... I missed this post... Brad something is definitely amiss. Thermistors read a scale of -40 to 140... but it is NOT in C, it's in F. 140C is around 270degF !!! That's damn near twice what the upper end of the range for that sensor is...
That table is DEFINITELY not scaled in C.
Old Feb 2, 2007 | 03:13 PM
  #36
brad8266's Avatar
Well it says C in both the ECT and IAT tables. Maybe it means F but they didnt change the letters in the software.
Old Feb 2, 2007 | 04:12 PM
  #37
foff667's Avatar
LS1TECH Sponsor
BTW frost...check out an 01+ file & you'll see the pe IAT adder IS in that scale -40 to 284*F so its possible that its in there, maybe not active though :shrug:
Old Feb 2, 2007 | 04:47 PM
  #38
Frost's Avatar
!doh! I posted a screenie of the table above I dunno....
Edit
and so Foff, what do you think of those outrageous adder values Brad found in his 00 table (that I can't get to even with his same verison of edit...) It SURELY cant be active...
Old Feb 2, 2007 | 05:21 PM
  #39
brad8266's Avatar
it would be cool if it is active though.
Old Feb 2, 2007 | 05:26 PM
  #40
usd2sing's Avatar
i believe some of the dry nitrous guys are using this table with success.
check out robert56 in the nitrous section. he has a write up on it...
