Tach not working
Old Jan 28, 2007 | 11:02 PM
STKN1STGEAR's Avatar
Default Tach not working
Hi,
I installed a new LS2 into a 99 camaro. after that I found that the tach wasn't working. After cnnecting the computer to the OBDII port and seeing that it was reading the tach just fine, I started looking at the wireing. didn't fnd any problem. what should I like at next? all the other factor gages work fine. didn't fnd any fuses blown.
Any help would be greatly appreciated
Al
Old Jan 28, 2007 | 11:21 PM
horist's Avatar
are all the other gauges working? I thought the tach speed wsa part of the "serial stream" to the gauge cluster
though now that I think of it... there is a wire that is just tach... (#10 wire jumps to head... not sure which connector) ... you have to intercept it for a MSD window switch for example ...
I'm thinking it's probably a wiring issue... a couple years ago I had an intermitent tach problem... ended up being that the spot where I spliced years ago for an MSD window switch (long since removed) wasn't making a good connection ... I could log RPM via the DLC since that's only talking to the PCM... but the feed from the PCM to the tach was the problem
Old Jan 28, 2007 | 11:24 PM
horist's Avatar
ok... checked my tuningdocs directory (can't post a link since it's not something I designed and I don't have permission of author to post)
Pin 10 on the red connector, it's white... provides a tach signal ...
Old Jan 28, 2007 | 11:38 PM
Yes All the other gages work. This car has ever had another tach installed. I can read the tach throught the ODBII using EFILive. does this have anything to do with the cam sensor? I have an issue with the cam sensor throwing errors and not reading properly.
Thanks
Al
Old Jan 28, 2007 | 11:40 PM
Can you PM the link to me?
what red connector?
and what do you mean it's white?
Al
Old Jan 29, 2007 | 02:30 PM
Ttt...
