Sd Tuned/snow Meth Controller (maf)
Old Jan 29, 2007 | 01:39 PM
anarchy99's Avatar
Default Sd Tuned/snow Meth Controller (maf)
Alright, car is 3 BAR SD tuned (hptuners) but I wanted to start messing with my meth injection. The Meth injection is controlled by a Snow Performance MAF variable controller. My question is because the car is SD tuned, would I still be able to use the MAF variable controller that uses the varying voltage in the MAF to start and progressively control the meth injection? I didn't know if the MAF still functioned the same way, but the signal was ignored by the PCM. Also, would I need the MAF fully hooked up to use it? Thanks.
Old Jan 29, 2007 | 03:47 PM
Frost's Avatar
It'd be nice if that thing would let you hop an output from your MAP sensor for it's ramping... Any words to that effect in it's literature?
Old Jan 29, 2007 | 05:03 PM
anarchy99's Avatar
no word... I wonder if the MAP sensor ramps the voltage up like the MAF sensor does...
