Knock Sensor adjustment
Old Jan 30, 2007 | 03:40 PM
A-Dub's Avatar
Default Knock Sensor adjustment
Car in sig, has updated knock sensors. I have a fair amount of valvetrain noise and I was getting small amounts of knock (<1) in the lower rpm range and then a few degrees of knock when I shifted between 1800 and 3500 at part throttle. The car is an M6. Pretty sure its false, so I increased the global gain values by 1 and the small knock went away, but the shift knock stayed. I played around with it more and with the global gain table increased by 1, the decay rate doubled, and the attack rate halved, the knock went away. Have I taken too much out of the sensors for safety's sake? Any better way to go about it?
Old Jan 31, 2007 | 08:16 AM
A-Dub's Avatar
Someone has to have some input....
Old Mar 14, 2007 | 03:32 AM
danzel's Avatar
just curious, are you getting any hesitation at low rpms since the check engine light came on for the knock sensor ?
