Ls1 shiftpoints????
Old Feb 1, 2007 | 03:39 PM
youguessit's Avatar
Question Ls1 shiftpoints????
I have a 2002 camaro z28, auto... I need to know what good wot shiftpoints would be... and anything else pertainting to the transmission... it is set for the wrong rear, now it is stock.... I have headers, thermostat, intake, cutout, exhaust....
Old Feb 1, 2007 | 04:58 PM
SSpdDmon's Avatar
Make sure it shifts by 6100 and watch the 3>4 WOT shifts. They're the weakest...
Old Feb 1, 2007 | 11:25 PM
youguessit's Avatar
thanks... ill mess with it and see what happens.... i managed a 13.64 with bad slippage..... couldnt get it to shift....
Old Feb 1, 2007 | 11:54 PM
Frost's Avatar
Tuning won't help a failing tranny, and there is a lot you can do that can make it worse. Personally with your mods (and a good tranny) I would log and test to hit 6150 for 1-2 and 6100 for 2-3. Don't mess with any pressure related stuff if you have any kind of built tranny or shift kit.
Old Feb 2, 2007 | 12:29 AM
horist's Avatar
based on the info you stated in your first post...
... so is it wrong or correct?
if you ran a 13.6 with a slipping trans.... i'm hoping you are in a very high altitude area (denver?)
if your trans is slipping at that slow of ET... then doubtful tuning will help...
(if Manual transmission and lots of slippage , you need to learn to drive or replace the clutch ... no reason to run a 13.6 in an LS1 unless you're high altitude, bad clutch, failing auto, or can't drive stick)
but regardless.... stock valvetrain ... 100rpm max is safe IMHO (behond stock shifts... though 1-2 can be raised 200-300RPM)
if you need to shift from 3 to 4... time to change tire or rear gear (WOT 3-4 shift is death to a 4L60E)
basically comes down to: put some info on your car in your signature
if you are running a 13.6 with major slippage... deal with the slippage issue before you start running the RPMs higher
edit:
saw that you are running an auto for sure
if you're seeing slippage then start shopping for a new transmission... unless you're at high altitudes, a 13.6 is pretty poor for an LS1
you need to deal with the slippage issue before you start messing with shift points ....
Old Feb 2, 2007 | 11:37 AM
youguessit's Avatar
Thanks... i lowered my shift points... my tranny is failing... i c that now... i live in houston and race at baytown... i had to lower my shift points rediculously low... 5700 rpms.... i will probably get it built... i alrealy screwed up the rear... im getting a moser12. Thanks again.
