fuel pressure
So unless you have read pressure over the entire engine load range, then dont bet that its going to be 65 across all pressure readings, because it likely wont.
Or don't worry about it and tune your VE based on your current IFR table, it will change shape to suit. Not ideal, but most people don't have FP gauges for logging anyway so in effect they are doing this already.
Or don't worry about it and tune your VE based on your current IFR table, it will change shape to suit. Not ideal, but most people don't have FP gauges for logging anyway so in effect they are doing this already.[/QUOT
i just checked the pressure with a guage at idle, but like you said i'm sure it dosent stay 65 across the board.i just did it because i was going to install a hot wire fuel pump kit and wanted to check pressure befor and after.
now about tuning VE and IFR i have no idea howto do it. i do have HPtuners but totaly suck at tunning. the only thing i know how to do is tune for injectors and even that took me a while. i have tried and tried to learn how to understand and tune my car but i just dont understand.
