6.0 Popping
When The Car Is Decelerating It Seems To Be Popping Out The Exhaust.
What Is The Next Step That I Would Try To Figure Out The Problem
I Seem To Have Approx 48 Lbs Fuel Pressure.
If I Was To Buy One Of The Aftermatket Systems Would It Be Able To Tell Me If There Was Something Wrong With My Fuel Curve?
Thanks
Eric
Throttle cracker too should not be effecting accelleration popping.
It Adds air to keep the vehicle from stalling while the vehicle is in motion. A stalled vehicle means no brakes. So it is a safety add on to make sure a stall never happens.
IF THE POPPING CHANGES when you are adding or pulling from that table, then i would say it is effecting your fuel ratio, So, i would be checking for a major lean condition.
Well the throttle cracker was effecting it. Turning it off resolved my issue.
Also he said "When The Car Is Decelerating It Seems To Be Popping Out The Exhaust."
So that would be decel
lolWhy don't you try helping this guy out?
I was trying to give him a hand, I wasn't asking for help but thanks for explaining what the throttle cracker does though.
